1999 Ford Taurus rear hub and bearing assembly
1999 FORD TAURUS
C8309
Drive Train Axles Bearings problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
I am trying to replace the rear bearing hub assy on my 99 ford tauris the instrusct instruct me to take the nut off of the rear bearing stud . I don't know how to get the metal nut retaing off and what to do about replacing it. How do I get the nut off and what size socket do i need
thanks
Oct 27, 2008 at 4:26 AM
BMRFIXIT
  • 19,053 POSTS
Are u sure ! do u really want to do this !!
I’m just kidding 1
you can use a flat head screw driver and a hammer
tap it in just a bit ,around the edges and take the cap off
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 27, 2008 at 10:54 AM
