Radiator fluid coming out of the overflow cap?
145,000 MILES • 4 CYL • FWD • AUTOMATIC
HAPPY_CAMPER1015
There is Radiator fluid coming out of the overflow cap..I put a new cap on, and it's still doing the same thing....
Apr 1, 2010 at 9:28 AM
SQM
  • 6,383 POSTS
Is your engine overheating?
Usually the coolant will come out of the radiator cap when the engine overheats.
Since you changed the cap, overheating might be the reason coolant is coming out of the cap.
An engine can over heat for various reasons.
It could be a stuck thermostat, faulty water pump, bad radiator, in operative cooling fans.
Any of these can trigger the engine to overheat.
Remember to work on the engine when it is cold.
You might find these articles helpful:
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Aug 13, 2021 at 8:27 AM
