1999 Ford Taurus Radiator
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANKEETHLER
I cannot find the radiator cap on my '99 Ford Tuarus to save my life! I know where the resevior is and I believe I've been told I don't even have a readiator cap but something tells me there has to be one. Am I wrong?
Thanks!
Dan
Nov 13, 2009 at 8:35 AM
BMRFIXIT
  • 19,053 POSTS
No cap on the radiator
Aug 24, 2020 at 5:25 AM
DANKEETHLER
[quote:e0a6b70104="BMRFIXIT"]No cap on the radiator[/quote:e0a6b70104]
So if I need to add water...?
BMRFIXIT
  • 19,053 POSTS
Coolant is added through the plastic bottle on the right fender has a cap on it its a turn type and not like the old radiator lock type Its under pressure do not open if engine hot coolant will BURN you
https://images.2carpros.com/forum/automotive_pictures/99387_bottle_1.jpg
DANKEETHLER
Ok so is that what I've been referring to as the reservoir then that I add water to?
BMRFIXIT
  • 19,053 POSTS
Overflow tank
and where to add coolant to the system
no other way
DANKEETHLER
[quote:d540acef6f="BMRFIXIT"]Overflow tank
no other way[/quote:d540acef6f]
I knew there was a good reason I didn't like this car, haha.
Thanks a lot!
Aug 24, 2020 at 5:26 AM
