1999 Ford Taurus power windows
MSMOCHA
Electrical problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic
my main driver side power window controls do work...but the controls for the 3 other windows do not work located on each respective door. What should I troubleshoot?
Dec 18, 2008 at 4:38 PM
DAVE H
  • 13,383 POSTS
I would be checking the "lock out" function on the master drivers door switch ?? also have the vehicles GEM read for fault codes ?
DESCRIPTION & OPERATION
Power windows are operated by reversible type motors mounted with each window regulator. A master control switch located on driver's door can operate all windows. Single switches in each passenger door can be locked out from the master switch.
One-touch down feature will lower driver's window to full down position with a brief touch on the window switch. A delayed accessory feature will allow window operation for 45 seconds after ignition is turned off. One-touch down and delayed accessory functions are controlled by the Generic Electronic Module (GEM). The GEM has the ability to store and output Diagnostic Trouble Codes (DTCs) and Parameter Identification (PID) values.
Dec 18, 2008 at 10:44 PM
