1999 Ford Taurus power steering pump and front axle...
1999 FORD TAURUS
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
AALIYAHJEEZY
We have replaced the power steering pump on my husbands ford taurus twice in six months because the turning radius was extremely tight. It has been two months since the last repair and the problem has reoccured. we believe that the problem is more than the pump, and we have been told that the front axle is shot as well. do you have any idea what could be causing the power steering to keep going out if there is no fluid leak and the pump is not to blame? also, what is the price range to replace the front axle (parts)?
Thank You!!
-F.O.R.D= fix or repair daily!!!!!, Uniontown PA
Mar 20, 2010 at 7:23 AM
BMRFIXIT
  • 19,053 POSTS
Check and suspect rack and pinion, flush power steering fluid
Axle is about $70 to $125 for park or a remanufactured, or rebuilt
Mar 20, 2010 at 11:40 AM
