1999 Ford Taurus power steering
114,000 MILES • 6 CYL • FWD • AUTOMATIC
BGILL21
very hard to turn wheel when stopped.gets a little easer the faster you go . vac system the best i could refilled with mercon V. recon pump 5 years old. do the 99 taurus have power steering filter or cooler?
May 27, 2010 at 1:25 AM
BMRFIXIT
  • 19,053 POSTS
possibilities many
leak in the system check system fluid if low
add and turn wheel stop to stop check for leak
bad P/S pump
defective rack and pinion
no P/S filter
May 27, 2010 at 11:10 PM
