engine overheating
DALCHRO08
Engine Cooling problem 6 cyl Two Wheel Drive Automatic 115000 miles
I just replaced water pump and thermostat; system was flushed and leak by timing belt cap and gasket was fixed and sealed and still, the engine is overheating and the boiling antifreeze mixture comes out through reservoir tank cap with a lot of rust. Let me mention that heater was condemned and sealed by prior mechanical work. What is the problem? I suspect that the radiator is clogged.
May 11, 2010 at 1:41 AM
JCHANNAJR
  • 13 POSTS
Rusty water -- I would say a blockage in radiator or in a hose. I would flush system again. I currently have same issue, which is next on my list after I solve current issue. Likely right on with a clogged radiator.
Again -- I am not a mechanic...but that would be the direction I started in.
May 11, 2010 at 11:25 AM
