1999 Ford Taurus OBD 2 says speed sensor.
1999 FORD TAURUS
DARWINR
Electrical problem
1999 Ford Taurus 6 cyl Automatic 210000 miles
I had a speed sensor put into this car and it ran perfectly fine. Then a Transmission gear cable was installed and the car hasn't been the same since. Now the speedometer or odometer won't move at all. The air system will not work. and the power steering system is out of wack. what could this be? A wiring issue?
Jun 22, 2010 at 10:38 AM
  • 31,937 POSTS
If this happened when the cable was installed, i would be taking it back and getting them to check that they have not disturbed any wiring when doing the work,
mark (mhpautos)
Jun 22, 2010 at 10:45 AM
