1999 Ford Taurus NO heat
103,000 MILES • 6 CYL • FWD • AUTOMATIC
DALE R VIG
Air works good , but no heat at all.
Oct 8, 2008 at 7:33 AM
BMRFIXIT
  • 19,053 POSTS
Suspect blend door actuator
also check heater hoses if both hot if not u may need to have it flushed
Engine cool
lower the coolant level
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three times watching what leaving the heater core you are looking for the good flow and clear water to run throw
check thermostat and replace too
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 8, 2008 at 1:09 PM
