No Brake Pressure
SSNETZ
  • 1999 FORD TAURUS
  • 6 CYL
  • 109,000 MILES
I Replaced the Front Rotors, brake pads, calipers(new not rebuild) & my Master cylinder (New Not rebuild). I bled the master cylinder on the bench prior to installing it. I then bled the entire brake system. I do not see any Air bubbles coming our of the bleeders. I have pressure on my brake pedal when the ingnition is in the off position. Once I put the ingnition in the on position I lose all pressure and the pedal goes to the floor. If the engine is running I need to pump the brake pedal to build up pressure so that the brakes will engage. I had this same pressure issue prior to changing the master cylinder. I thought that was bad that is why I replaced it. I did not have this issue when I installed new brake lines to the rear brakes. I also had to change the calipers rotors, pads to both back brakes ( 6 months ago)
Friday, September 17th, 2010 AT 9:55 PM
  • 110,053 POSTS
Check the front rubber hoses to the calipers to make sure they are not expanding when you use the brakes.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Let me know what you find.
Monday, April 5th, 2021 AT 12:03 PM
