1999 Ford Taurus my horn and cruise control stop working
13,800 MILES • 6 CYL • 2WD • AUTOMATIC
MIKENANCY78
I called the Ford Dealer here and he told me the reason my horn and cruise control stop working was because I needed to change the fuses. I went and got new fuses and replaced all the fuses, the horn and cruise control still didnt work. Then I was told I needed to replace the clock spring in the steering, I took the car to the shop and they replaced it for me, after they replaced it they called me and told me it didnt need replaced, the part was in good condition, the horn and cruise control is still not working, they didnt know why. Now what do I do? Im not worried so much about the cruise control, I can live without that, but I need a horn. Can someone please tell me what I need to do now?
Jul 27, 2008 at 12:22 PM
2CARPRO JACK
  • 11,533 POSTS
Did you replace fuse 19 in the underhood power center?. Besides the clockspring, I dont see anything else they share
Jul 28, 2008 at 12:38 AM
MIKENANCY78
Yes I changed the #19 fuse, all the fuses in the car are now new, I replaced them all.
Jul 28, 2008 at 8:56 AM
KLSHIEL
  • 163 POSTS
Was the old fuse burned out? if it was you may have burned up a wire somewhere. If not a connection may be bad, or a wire may be broke.
Jul 28, 2008 at 9:20 AM
MIKENANCY78
no the fuse wasnt burn out, no black on it anywhere, but I replaced it anyway.
Jul 28, 2008 at 10:09 AM
2CARPRO JACK
  • 11,533 POSTS
Grab your test light. Go to underhood power center and remove the horn relay.Slots 1,3 should have power,2 should turn to ground when horn button is depressed.If all ok, install relay and test at horns for power with horn pushed
Jul 29, 2008 at 12:40 AM
