1999 Ford Taurus Misfire 303 and lean code 174 with code 40
1999 FORD TAURUS
104,500 MILES • 6 CYL • FWD • AUTOMATIC
DAVIDANDTHEKATRINACAR
I have a duratech with the 303 misfire code along with the 401 and 174 code I have replaced the egr valve the egr back pressure sensor the pcv valve the 2 down stream o2 sensors the coil pack wires plugs fuel filter the iac valve cleaned the maf sensor replaced the plentum gasket along with some other things I can't think of right now still has a rough idle and a misfire along with the codes
May 25, 2009 at 2:01 PM
YASGER
  • 83 POSTS
try spark plugs first, then spark wires...
[quote:e928f7c381="Davidandthekatrinacar"]Engine Performance problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 104500 miles
I have a duratech with the 303 misfire code along with the 401 and 174 code I have replaced the egr valve the egr back pressure sensor the pcv valve the 2 down stream o2 sensors the coil pack wires plugs fuel filter the iac valve cleaned the maf sensor replaced the plentum gasket along with some other things I can't think of right now still has a rough idle and a misfire along with the codes[/quote:e928f7c381]
May 30, 2009 at 10:14 AM
