1999 Ford Taurus Intermittent Start Ups
141,000 MILES • 6 CYL • 2WD • AUTOMATIC
BMMROHRER
Hi I am having a problem for the last couple months with my Taurus. In the morning it usually starts right up. I drive it fine. If it sits for a long time (like hours), it will start up again. But if I drive it for errands or something, with a lot of start ups in a short period of time it eventually wont turn over when I want to start it again. It really sounds like it wants to but it just wont turn over. I have done the following... replaced battery, checked alternator (is fine), replaced spark plugs, replaced fuel filter. Running out of ideas. It's VERY random. If it doesnt start I usually wait an hour or more and then it just starts up like nothing was wrong. It's very annoying. Any help out there? Thank you!
Jul 28, 2010 at 10:51 PM
  • 75,988 POSTS
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it not to start-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
May 3, 2017 at 4:47 AM
