1999 Ford Taurus intermitten overheating
84,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFDALY
once a week or so, temp gauge jumps real high (im mean REAL high) at that point i heard the electric fan kiclk on cooling it down to normAL RANGE. ONCE, IT HAPPENED JUST AFTER A THUNDERSTORM---OUTSIDE TEMP WAS APPROX 75 DEGREES AND JUST AROUND SUNDOWN. AND ANOTHER TIME IT DID IT 10 OCLOCK AT NIGHT WITH OUTSIDE TEMPS IN THE MID 60'S. ON A HOT SUMMER DAY, SAY IN MID 90'S, IT HASNT HAPPENED. IS THIS SOME KIND OF ELECTRICAL, THERMOSTATE PROBLEM? WHERE DO I START LOOKING?
Sep 8, 2009 at 12:07 AM
JGAROFALO
  • 489 POSTS
[quote:17f2d45e15="jeffdaly"]Engine Cooling problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 84000 miles
once a week or so, temp gauge jumps real high (im mean REAL high) at that point i heard the electric fan kiclk on cooling it down to normAL RANGE. ONCE, IT HAPPENED JUST AFTER A THUNDERSTORM---OUTSIDE TEMP WAS APPROX 75 DEGREES AND JUST AROUND SUNDOWN. AND ANOTHER TIME IT DID IT 10 OCLOCK AT NIGHT WITH OUTSIDE TEMPS IN THE MID 60'S. ON A HOT SUMMER DAY, SAY IN MID 90'S, IT HASNT HAPPENED. IS THIS SOME KIND OF ELECTRICAL, THERMOSTATE PROBLEM? WHERE DO I START LOOKING?[/quote:17f2d45e15]
Some possibilies:
Sticking thermostat.
Coolant temperature sensor intermittent failure.
Integrated controller - contains relays for the ECM, fuel pump, and cooling fan. Especially check the ground connections.
Sep 9, 2009 at 6:54 AM
