Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Climate Control
Heater
Relay
1999 Ford Taurus heater relay
1999 FORD TAURUS
65,000 MILES • 6 CYL • FWD • AUTOMATIC
LEON104
MEMBER
1 POST
able to have heat with defroster, but no heat thru vents into cabin of car, thermostat was changed, and antifreeze was ok
Oct 21, 2008 at 8:20 AM
Experienced Mechanic
Hi leon104 and welcome to 2carpros
You need to check the air mix/blend/mode doors could also be a vacuum or an actuator problem
Oct 21, 2008 at 10:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
