1999 Ford Taurus heater core - door adjuster
113,000 MILES • 6 CYL • FWD • AUTOMATIC
MISSLEAD
My problem is with the heater door adjuster under the dash board/glove box continually flapping. The air condition on "blue" cool cycle does not do this but the turning it to the "red" heat cycle the flapping starts. So, my question is how can I temperarily jimmy the door to stay open or closed so the heat works and the defroster with warm air.
Thank you, and wanting your reply ASAP.
Julee
Oct 28, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
It has an actuator on it and it need to be replaced
remove the actuator and the n u can place it in the position that you like
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 28, 2008 at 2:20 PM
