1999 Ford Taurus harmonic balancer removal
62,000 MILES • 6 CYL • FWD • AUTOMATIC
BCRAWFORD
I need to get timing cover off of my 3.0 duratech. I have the first pull off ( left hand thread easy enough). the next peice is where i am stuck. the part that is threaded into the balancer itself is it right or left hand thread? then the bolt that goes in to the crank itself right hand or left hand thread( my guesss is right like most)
Jan 15, 2008 at 8:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:da6f87f548="bcrawford"]Engine problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 62000 miles
I need to get timing cover off of my 3.0 duratech. I have the first pull off ( left hand thread easy enough). the next peice is where i am stuck. the part that is threaded into the balancer itself is it right or left hand thread? then the bolt that goes in to the crank itself right hand or left hand thread( my guesss is right like most)[/quote:da6f87f548]
right hand
try to tighten it and that will loosen it
Jan 15, 2008 at 9:55 AM
