1998 fuel filter location
169,000 MILES • 6 CYL • 2WD • AUTOMATIC
HONEYBEE60
Where is the fuel filer located on a 1998 Ford Taurus?
Mar 31, 2011 at 3:49 PM
WRENCHTECH
  • 20,758 POSTS
The fuel filter is located at the Right Hand rear frame rail adjacent to the Right Hand front corner of the fuel tank.
See the attachment below
Mar 31, 2011 at 3:54 PM
BERKLYM62
  • 5 POSTS
1991 ford taurus gl, about 135,000 miles, i think, with 3.0 NON-sho engine. chilton says how to change fuel filter, but not where it is? also, how can i relieve fuel pressure without buying the "special tool"?and, lately, the car has been stalling at idle, but only afterrunning well like at hiway speeds,stop at a red light, it starts idling rough, then knocks and backfires thru the intake manifold, then dies. sometimes, it might start right back up again, but usually, i have to wait AT LEAST a couple of hours, or over night, to get it running again. then, it runs like there wasnt any thing wrong at all, till it does it again! i only paid $270.00 for the car, ran very good when i bought it, so i dont want to put too much $$$ into it.
Mar 10, 2019 at 4:43 AM (Merged)
TAURUSWHEEL
  • 718 POSTS
Fuel filter,I believe, is located in front of the right rear wheel, up on the frame,held in place with a hose clamp..to relieve pressure in the system, unplug the connector from the fuel pump shutoff located in the right rear quarter panel, usually right near the rear marker lamp.. accessed thru a small door on wagons and thru the panel on sedans, may have to remove the panel on sedan... for all,unplug the connector, then start the car, it'll die off quickly you're all set to change the filter..
BERKLYM62
  • 5 POSTS
THANK YOU! it is 9:48pm now, but i will look tomorrow, and see if it is there! FINALLY!!! i got some info on this thing! thank you so much, again!
BERKLYM62
  • 5 POSTS
ok, yes, thank you for your help, found the filter, right where you said it was! already replaced the filter, changed the oil and oil filter, as well. i simply cant figure out how CHILTON can tell you how to remove it, but wont tell you where the hell it is, first :roll:
TAURUSWHEEL
  • 718 POSTS
Beautiful, sometimes that clamp can be a pain..
WEBBER123
could you tell me the location of the fuel filter and if any special tools wilol be needed for removal
MERLIN2021
  • 17,250 POSTS
Under the car near the right rear door, they use plastic clips to hold it on the line, spread them with your finger...
LEGITIMATE007
  • 5,121 POSTS
Make sure that you relieve the pressure too. it may be a lot safer and easier too.
WEBBER123
Yes. You helped a lot, thank you. John :lol: :!:
MERLIN2021
  • 17,250 POSTS
Mission accomplished! Your welcome!
WONBYJESUS
where is the fuel filter for this car? I need to know where the fuel filter is and if there is one or two fuel filters for this car!
  • 110,251 POSTS
It is under the vehicle, passenger side, below seating area, mounted in the fuel line. There is only one.
R.LYLE
fuel filter located on 2000 ford taurus dohc
SATURNTECH9
  • 30,868 POSTS
The fuel filter is located on the LH frame rail.
BMRFIXIT
  • 19,053 POSTS
Under rear passenger side of the car by the fuel tank
CHRISTINAPEER
1992 Ford Taurus 6 cyl
BLACKOP555
  • 10,386 POSTS
thers one in the tank on the fuel pump, one inline from the tank and the engine, and theres one in the fuel pressure regulator.
if you dont like the answer, give me what one your looking for.
ABRAH
Where is the fuel filter located on a 97 Ford Taurus? It is a V6 3.0 with about 95,000 miles on it
Mar 10, 2019 at 4:44 AM (Merged)
BOOTDOG
  • 665 POSTS
passenger side, under then vehicle, towards the back. follow the fuel lines to the tank and you'll see it.
ABRAH
It isn't in the fuel tank though is it?
TAURUSWHEEL
  • 718 POSTS
As the poster said, it is in front of the right rear wheel, clamped to the frame, you'll see it.. are you doing it yourself??? Find your fuel cutoff(inertia) switch, located in the right rear quarter panel in front of the taillight, may be an access panel to remove.. find the switch, unplug the connector, then start your car it should die off immediately, now you're set to change the filter,, reconnect plug when you're done, fire it up.. if for some reason no-start, push the reset button on top of the shutoff
LUCKYINDIAN
2002 Taurus. Where is the fuel filter?
  • 75,988 POSTS
What liter engine ?
LUCKYINDIAN
BCAMRENS
where is the fuel filter located
TAURUSWHEEL
  • 718 POSTS
Above the right rear wheel, held with a hose clamp.. couple of hairpin clips hold it to the fuel lines.. Read the instructions, easy to do.. use a chilton's book for help
CURTDOG
Where is the fuel filter located on the 2000 taurus. Is it inside or outside the tank. Does the tank need to be removed or can it be accessed from inside the car or trunk?
BLUELIGHTNIN6
  • 16,542 POSTS
It is under vehicle, passenger side, below seating area, mounted on frame rail in fuel line . You will need special fuel line disconnect tool for this job.
BRIANSANDERS89
2004 Ford Taurus 6 cyl Front Wheel Drive Automatic
were is the fuel filter located?
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_ff_1.gif
GMAN1957
Car stopped on the freeway going to church this morning.
Where is the fuel filter located on the 1990 Ford Taurus?
  • 75,988 POSTS
FUEL FILTER: The filter is mounted on the underbody next to the RH front corner of the fuel tank.
RACHELLE MELTZER
Where is the fuel filterlocated on the Ford Taurus 2002?
JDL
  • 16,098 POSTS
Some of my information says, passenger side rear on the frame rail, in front of rear tire.
