1999 Ford Taurus Ford Taurus sounds like truck
1999 FORD TAURUS
ROGER KEILIG
Noises problem
1999 Ford Taurus 6 cyl Automatic 150000 miles
The car has been driving increasing louder, sounding like a truck with rough tires or with near flat tires.
Oct 4, 2010 at 12:55 AM
  • 110,244 POSTS
Are the tires in good shape and not cupped? Does the sound change when turning?
Oct 4, 2010 at 3:15 AM
ROGER KEILIG
The problem is not the tires or the alignment. It's a drive train noise. The engine and the transmission act fine. Could it be a torque converter? Thank you
Oct 4, 2010 at 10:32 AM
  • 110,244 POSTS
I would lean more toward a wheel bearing than the torque converter. Does the noise change at all when turning?
Oct 4, 2010 at 3:07 PM
ROGER KEILIG
You asked if the noise varied when turning - Not that I could notice. The wheel bearing does sound like a possibility, since the car seems normal in all other respects. Any other possibilities? It's loud enough, but not a whine or gravelly.
Oct 6, 2010 at 12:16 PM
  • 110,244 POSTS
On this type of car, that is my first guess. The torque converter would change pitch with RPM's.
Oct 7, 2010 at 6:12 AM
