1999 Ford Taurus First SPEEDOMTER quits working..then O/D O
1999 FORD TAURUS
MATTHEW785
Engine Performance problem
1999 Ford Taurus Two Wheel Drive Automatic
First the speedometer quits working. Then the O/D OFF light comes on in the RPM gauge. Then, the engine lunges, slow to excellerate. I looked in my manual, no mention of a O/D indication light.
Jun 17, 2010 at 11:30 AM
BMRFIXIT
  • 19,053 POSTS
flashing OD light is an indication for a present codes in the T CM
and since the speedometer is not working 1st should suspect and check VSS (vehicle speed sensor)
check for codes
Jun 17, 2010 at 3:50 PM
