1999 Ford Taurus engine wont idle
190,000 MILES • 6 CYL • FWD • AUTOMATIC
LLS58
upon starting, engine races to 3000rpms and then drops and will not idle and dies. if you can keep it running it runs good until you stop then it dies. changed plugs and wires, new egr valve . pulls code for oxygen sensors., mixture too lean bank 1 and bank 2.
Nov 16, 2009 at 4:16 AM
BMRFIXIT
  • 19,053 POSTS
Check for a vacuum leaks
check PCV valve and intake manifold
check MAF sensor
Nov 16, 2009 at 12:45 PM
