1999 Ford Taurus engine stalls while driving
209,000 MILES • 6 CYL • FWD • AUTOMATIC
JHOOTA
I have a 99 Ford Taurus, that stalls while driving then will not start back up unless you let it set for at least a half hour, to just stall out again. There is no check engine light on. We have changed the fuel filter, plugs, and wires, 2 vacuum seal leaks and still same problem. What else could it be? Tired of spending money to have it not fix the problem.
Mar 18, 2008 at 10:37 PM
LEGITIMATE007
  • 5,121 POSTS
ignition module and crank position sensor should be checked
Mar 19, 2008 at 1:29 AM
