1999 Ford Taurus Driveability
135,000 MILES • 6 CYL • FWD • AUTOMATIC
202STEVEO
1999 Ford Taurus does not move when placed in gear. No Low, High, Overdrive or Reverse. There was not any symptoms like hard shifting,,,slipping,,,grinding,,,or leaking. Fluid level is OK. With the engine still running,,the vehicle just coasted to a stop, like it was put into neutral.
Thank You for any help
Aug 25, 2009 at 4:02 AM
BMRFIXIT
  • 19,053 POSTS
Check axles
suspect internal tranny failure
Aug 25, 2009 at 10:40 PM
