1999 Ford Taurus Door locks
KEVI
Electrical problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic
All four doors will not unlock or lock when you push the botton, on both front doors. I notice that it will click or move a little but it will start to acted as if the battery is drained and the back doors will not unlock by pulling on the handle (as if the child lock was on)
Jan 17, 2009 at 8:16 AM
  • 110,251 POSTS
Hi:
The first thing I would check would be the driver's side lock switch. I believe on your model, it supplies power to each door.
Jan 19, 2009 at 10:13 AM
KEVI
[quote:89e1872058="Jacobandnickolas"]Hi:
The first thing I would check would be the driver's side lock switch. I believe on your model, it supplies power to each door.[/quote:89e1872058]
After unpluging the driver side I try the rightside door and it still did the same thing ( it would not unlock or lock the remaining doors
Jan 19, 2009 at 11:04 AM
KEVI
Jan 19, 2009 at 11:32 AM
  • 110,251 POSTS
Are you getting 12 volts to the switch?
Jan 19, 2009 at 12:20 PM
KEVI
I am getting 12 volt, but I do notice that when I first push the lock on the passenger side it start off strong but it get weaker the more I push the lock botton. And the lock will not move
Jan 19, 2009 at 1:13 PM
