1999 taurus it overheat, blow head gaskets,got a lot of cooling fluid on cylinders. Replace gaskets,new spark plugs.The motor will turn but not start. Check fuel pump,is working, 42psi,check plugs they got fire, check timing it's on time,don't know whatelse to do.Any suggestions
Aug 2, 2008 at 1:44 PM
