[quote="josram"][quote="josram"]Engine Mechanical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 138000 miles
1999 taurus it overheat, blow head gaskets, got a lot of cooling fluid on cylinders. Replace gaskets, new spark plugs. The motor will turn but not start. Check fuel pump, is working, 42psi, check plugs they got fire, check timing it's on time, don't know whatelse to do. Any suggestions. Check for pulse on injectors, got pulse. Spray some starting fluid. No luck, doing same thing, motor turns but don't run. IS there a way the I can test the injector, and see if they spraing. Thinking may mesthem up, with all the antifrez the got on cylinders.
Tuesday, August 5th, 2008 AT 9:47 PM
