1999 Ford Taurus cooling
PAWS1939
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
coolant level light stays on, jumped out wire harness , checked switch both ok . light still on
Sep 22, 2009 at 11:03 AM
BMRFIXIT
  • 19,053 POSTS
U should not try to bypass the switch
PCM look for a resistance from the switch
If equipped Engine Coolant Level Switch is located On Coolant Reservoir
use an OBDII reader and check for codes do you have any (p1881,p1882,p1883,p1884)
I would clear the codes and start engine and check for codes again
Sep 22, 2009 at 11:30 AM
