1999 Ford Taurus compressor
LBILBREY
Air Conditioning problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
a/c compressor comes on but goes off after about 5 seconds and wont come back on. have already replaced controls, compressor, cycling switch, relay. checked all the fuses
Jun 24, 2010 at 9:49 AM
BMRFIXIT
  • 19,053 POSTS
Do you have enough 134A refrigerant in it
what your high side and low side system readings
check for codes
Jun 24, 2010 at 1:37 PM
LBILBREY
put 2lbs of 134 in it and forgot what the readings where but i will put the computer on it tomorrow to see if it tripped any codes thanks
Jun 24, 2010 at 2:10 PM
BMRFIXIT
  • 19,053 POSTS
Let me know what you come up for codes
and if need to look them up
Jun 24, 2010 at 2:40 PM
