1999 Ford Taurus cam sensor
EAGLERISING
Engine Mechanical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
My dad has a 1999 ford taurus after it sits over night it will not crank the other day i put a code reader on it and the code was po102 we put a crank sensor and it still does the same thing its like the lifters are bleeding offit misfires for a while but i keep cranking on it it finnally runsand runs good I was wondering if it has a cam sensor and if that would be the problem?
Nov 24, 2008 at 10:58 PM
ZACKMAN
  • 4,202 POSTS
P0102 deals with Mass Air Flow sensor circuit low input. Cam sensor location: 3.0L OHV rear of engine block, between cylinder heads
https://images.2carpros.com/forum/automotive_pictures/55316_tauruscamsensor_1.jpg
3.0L DOHC left front of engine, below valve cover
Nov 25, 2008 at 3:07 PM
