1999 Ford Taurus backfiring
190,000 MILES • 6 CYL • FWD • AUTOMATIC
PREACH128
I have had this car about 2 months.It runs rough when you first start it up.And when you start moving in it with the engine cold,it backfires up front.I had it checked for codes and it showed up the O2 sensor Bank 1 sensor 2.i had that replaced,as well as a vacuum line with a whole in it.I also had the plugs and wires checked.It clears up on its own after we are on the road a short time.But I know with it running like that for that short time is probably why it gets less than 16mpg Any solutions? I have the 3.0 engine with the U engine code
Mar 27, 2010 at 6:46 AM
MERLIN2021
  • 17,250 POSTS
The exact sensor code would be helpful there are several codes for O2's, but during warm up the O2 isn't used! Your problem could be a dirty MAF, a weak ECT(engine coolant temp) sensor. Or a fuel pressure problem. The ect is only about $20.00 and just screws in and out, replace it when the motor is cold.
Mar 27, 2010 at 7:05 AM
