1999 Ford Taurus Alternator
CHRISTINE20
  • 6 POSTS
Engine Mechanical problem
1999 Ford Taurus 6 cyl Automatic
Just replaced the alternator and battery on Friday. Ran fine all weekend and today it died on me. It starts with a jump but doesn't hold the charge. two people looked at it and said the wire that connects to the alternator is not connected that well. It's supposed to click in and stay tight but it is loose and can be pulled out easily. Could this be the issue or could it just be a faulty alternator?
May 16, 2010 at 4:08 PM
  • 31,937 POSTS
Hi there,
I feel that the plug on the alternator is the cause of you problem, i would be getting this plug replaced ASAP.
mark (mhpautos)
May 16, 2010 at 4:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes a loose connection will definitely cause symptoms of a faulty charging system. need to have those cables and cable connections fixed
May 16, 2010 at 4:31 PM
CHRISTINE20
  • 6 POSTS
Thank you!
May 16, 2010 at 5:00 PM
CHRISTINE20
  • 6 POSTS
How would I go about fixing that?
May 16, 2010 at 7:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You can purchase battery cables for relatively low pricing at most local auto part stores. you will need to just remove the old cables, few bolts holds it on at each connection, then run the new cables.
May 17, 2010 at 6:14 AM
