1999 Ford Taurus Air Duct Passages
102,000 MILES • 6 CYL • FWD • AUTOMATIC
500C
The engine operates at normal temp, the heater fan motor moves air, the heater core hoses heat up to the touch when the engine reaches operating temp, I flushed out the heater core and it seems to be free from blockages. Why won't the heat get into the passenger cabin? Is there a gate that is not opening to allow air to pass over the heater core?
Nov 8, 2008 at 5:39 AM
BLACKOP555
  • 10,386 POSTS
both hoses are hot? then its not restricted and it is narrowed down to ducting.
i would have to say that the blend door inside is not working, it forces the air through the heater core when hot is selected. could be a bad switch, sticking door or inoperate vaccum/electric motor for controling it.
Nov 8, 2008 at 6:35 AM
