1999 Ford Taurus ac compresor
JACKSON10
Engine Mechanical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 280k miles
My A/C pulley stopped and is causing my belt to break. Could I remove the A/C compressor and get smaller belt and run it this way?
Apr 30, 2010 at 3:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you can but you may need to install a bypass pulley to keep the tension on the belt if the smaller belt doesn't fit right.
Apr 30, 2010 at 4:13 PM
