1999 Ford Taurus A/C
159,546 MILES • 6 CYL • FWD • AUTOMATIC
KROG123
  • 18 POSTS
my A/C was working and then all of a sudden it starts blowing out hot air and when I go to recharge it, it says that it has a charge.......I don't think the compresser is kicking on because it doesn't spin anymore when I turn on the A/C
Sep 8, 2010 at 4:32 PM
  • 110,251 POSTS
Have you checked to see if the compressor clutch is getting power?
Sep 8, 2010 at 11:57 PM
KROG123
  • 18 POSTS
[quote:efee1e69c1="Jacobandnickolas"]Have you checked to see if the compressor clutch is getting power?[/quote:efee1e69c1]
Sep 9, 2010 at 7:22 AM
KROG123
  • 18 POSTS
no.....is there a fuse that goes with the a c to help it work or no??????
Sep 9, 2010 at 7:23 AM
KROG123
  • 18 POSTS
[quote:04a948dfd4="krog123"][quote:04a948dfd4="Jacobandnickolas"]Have you checked to see if the compressor clutch is getting power?[/quote:04a948dfd4][/quote:04a948dfd4]
Sep 9, 2010 at 7:27 AM
  • 110,251 POSTS
Yes, there is a fuse. Check under the dash to check them. Also, under the hood may also be a fuse for it.
Sep 10, 2010 at 12:35 AM
KROG123
  • 18 POSTS
how much to get all fuses replaced on my 1999 Taurus SE
Sep 10, 2010 at 1:43 AM
  • 110,251 POSTS
Fuses are not too much, but you don't need all of them. If you choose to replace them all, I can't imagine they would be more than 25.00
Sep 10, 2010 at 4:34 PM
KROG123
  • 18 POSTS
what if I went to a local mechanic, could you give me an estimated price????
Sep 10, 2010 at 4:51 PM
  • 110,251 POSTS
I would say yes.
Sep 10, 2010 at 5:41 PM
KROG123
  • 18 POSTS
how much would I pay for a mechanic to replace all my fuses???
Sep 11, 2010 at 4:03 AM
KROG123
  • 18 POSTS
what do you think the cost would be???
Sep 12, 2010 at 5:32 AM
  • 110,251 POSTS
I would estimate that one would be able to replace all fuses in 20 minutes and the parts would be around 20 dollars in parts.
Sep 12, 2010 at 3:45 PM
KROG123
  • 18 POSTS
ok thanks if I have further questions i'll keep in touch
Sep 12, 2010 at 5:13 PM
  • 110,251 POSTS
You're welcome.
Sep 13, 2010 at 4:55 AM
