1999 Ford Taurus
ROBERTTHOMAS
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 105,000 MILES
I flushed out the coolant system by cutting a t in thehose and following directions. Since then everything is fine fluid is where it should be no leaks but the low coolant light comes on all the time I dont think I have an expansion tank with a sensor I cant see one any reason why light comes on
Sunday, March 29th, 2009 AT 3:32 PM
OBXAUTOMEDIC
  • 3,711 POSTS
The sensor is located on the bottom of the Overfill/Coolant Resevoir. I most cases you have to remove it to get to it and most likely if the level is at the recommended level then the sensor is faulty.
Sunday, March 29th, 2009 AT 3:38 PM
