1999 Ford Taurus Radiator Replacement Difficulty
COPY99
can someone tell me how long it takes to replace a radiator in a taurus and how hard is it.
Dec 5, 2006 at 10:09 AM
BOOTDOG
  • 665 POSTS
it doesn't take too long, but i do know it drops out from the bottom. it is more of a pain, (for a radiator), to change out compared to other vehicles. if u do this yourself you'll need to lift the font up, either with ramps or support with jack stands, take your time and make sure you have everything disconnected from the radiator before removing. if this seems too difficult then take it to a professional to install, or someone u know that has mechanical experience, if not yourself. hope this helps :wink:
Dec 5, 2006 at 11:04 AM
Suggested Repair
Lift the front on ramps or jack stands, disconnect everything from the radiator, and drop it out from the bottom. If that seems too difficult, have a professional or experienced mechanic install it.
Conversation Summary
The owner of a 1999 Ford Taurus asked how long a radiator replacement takes and how hard it is. The expert said it does not take too long but is more of a pain than on many vehicles because the radiator drops out from the bottom. They advised lifting the front, disconnecting everything before removal, and using a professional if the job seems too difficult.
