1998 Ford Taurus won't start
170,000 MILES • 6 CYL • FWD • AUTOMATIC
FROUGHY
Bought car from garage that had towed it off the interstate, with a blown head gasket. Replaced the head gaskets, timing chain, and spark plugs. It turns over and seems to want to start sometimes. The compression is only about 30 all around though. It gets spark and fuel also,but no compression. There is no mixing of the oil and anti-freeze. Any suggestions would help.
Sep 12, 2008 at 4:28 AM
MADMIKEJEEZY
check your timing buddy!
[quote:e468239e4d="froughy"]Engine Mechanical problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic 170000 miles
Bought car from garage that had towed it off the interstate, with a blown head gasket. Replaced the head gaskets, timing chain, and spark plugs. It turns over and seems to want to start sometimes. The compression is only about 30 all around though. It gets spark and fuel also,but no compression. There is no mixing of the oil and anti-freeze. Any suggestions would help.[/quote:e468239e4d]
Feb 17, 2017 at 7:00 AM
