Transmission problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
98 ford Taurus SE 6cyl 3.0 w/ AX4N trans.- Runs like a top, but suddenly wouldn't go into 2nd. Shifts into Low 1 & 2, reverse, OD and drive just fine. Just can't get out of 1st. Already serviced the tranny - fluid was fine and maybe just a smidge low. Shifted into 2nd no prob for about a minute on the test drive after the service, then went back to nothing past 1st. Changed the VSS with no improvement. Could it be a shift solenoid or valve body issue ? Thanks in advance !
Jun 23, 2010 at 12:24 PM
