Engine Performance problem
1998 Ford Taurus 6 cyl Front Wheel Drive 167000 miles
When the car is cold, it rune and idles fine. When I run 30 or more minutes, I must pull over wait a minute and restart, then runs fine for about 10 or less minutes, then must restart. Have added many new parts. MAF sensor, IAT sensor, wires, plugs, cleaned air cleaner intake, used multiple injection cleaners, new egr valve and solenoid, new intake manifold gasker with torqueX2. The vehicle when warm simply slows down to a stop. Engine keeps running. If I give it gas, it may die (most of the time. Tried a new coil (same results). Bought an OBDII tool which seems worthless.
Help
Al
Help
Al
Feb 6, 2010 at 4:14 PM
