1998 Ford Taurus transmission (?) issue
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAB1983
First time this has happened, but driving the car today, I noticed - about at the same time - that the speedometer had stopped working and that the car was not shifting out of 1st gear. Check engine light lit about 2 blocks from home. Got home, checked oil levels after allowing oil to settle, added a quart just to be safe. Still has check engine light lit, but speedo and gears shifting so far. This has never happened before. Opinions of what might be wrong?
Jun 6, 2008 at 10:40 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
Jun 6, 2008 at 10:44 AM
