temperature gauge goes all the way up
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAT0606
When driving, the temperature gauge goes all the way up to the top towards "Hot" but the light does not come on. Is this the beginning of a problem or Is there something that I need to put into the engine.
May 8, 2009 at 6:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If the temp. gauge is showing hot but the engine is not actually running hot then suspect faulty Engine Coolant Temperature (ECT) sensor. Usually located on the rear of the engine block, near the thermostat.
Thanks for using 2CarPros.com!
May 8, 2009 at 6:20 AM
