1998 Ford Taurus taurus RPM problem
80,000 MILES • 6 CYL • FWD • AUTOMATIC
KMASIARCZYK
Hello, I drive a 98' ford taurus that has around 80,000 miles on it. The car has a major problem and needs fixing. Almost everytimeI drive it this problem occurs where the car will be driving and then buck when it shifts then the RPM's will be higher then normal and then all of a sudden it will go back to normal. then back and fourth. for instance, I will be driving at 40mph at a little under 2,000rpm's then the car will just shoot up to about 2,800 rpm's stay there for awhile, then go back down. I replaced the fuel filter but that did not work. Then I took it to a transmission shop, got a new transsmission and still does the same thing. I replaced the MAS sensor and the same thing still happens. I am lost and have no clue what to fix and it is killing me. PLEASE help I really apprciate any feed back
Aug 4, 2009 at 9:30 AM
BMRFIXIT
  • 19,053 POSTS
I would be suspecting a tranny problem and or tranny electrical
codes would be 1st to check
check TCM for codes
and fix as needed if any
Aug 5, 2009 at 12:01 PM
