1998 Ford Taurus starting problem
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRUTT
Driving from Ontario to California, car wouldn't start after 5 days on the road. Cranks fine, oil fine, fuel fine, fuel getting to engine, got a good spark. Sprayed some QuickStart into the throttle and that works to start the car, which runs smooth at that point. Mileage running about 20mpg on the highway. Haven't taken it in yet, but any ideas on what might be the problem? First time in the car's life that it has had this problem, although the Service Engine Soon light has been on permanently for more than a year (mechanic back in Canada said it is not something to worry about).
Jan 18, 2009 at 5:59 AM
  • 110,248 POSTS
Hi:
If it starts with starting fluid, there must be a problem with fuel pressure. That is where I would start. Check the fuel pressure and let me know what you finds.
Jan 19, 2009 at 9:55 AM
