1998 Ford Taurus Stalls
135,000 MILES • 6 CYL • FWD • AUTOMATIC
QDH4455
Hi my car has been stalling out at complete stops. When I let it idle it also dies. And my serv. eingine light is on and I was wondering what this could be. I also have a water pump I beleave may b leaking as to becasue of where it drips from and there is a low colant light on Is that an easy fix?
Sep 16, 2010 at 6:41 AM
WRENCHTECH
  • 20,758 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 95 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Sep 16, 2010 at 7:11 AM
