Turbine Shaft Speed Sensor located at Left rear lower side of engine compartment, on rear side of transaxle.
Wheel Speed Sensor (Left Front)located at In left front wheelwell, mounted on brake assembly.
Wheel Speed Sensor (Left Rear) located at In left rear wheelwell, mounted on brake assembly.
Wheel Speed Sensor (Right Front) located at In right front wheelwell, mounted on brake assembly.
Wheel Speed Sensor (Right Rear) located at In right rear wheelwell, mounted on brake assembly
Aug 16, 2009 at 11:04 PM
