1998 Ford Taurus Shuddering when braking
DRSMITH724
Brakes problem
1998 Ford Taurus Engine Size unknown Two Wheel Drive Automatic 117115 miles
My vehicle shudders when braking. The higher the speed I am braking at, the stronger the shuddering. In addition the vehicle makes a creaking/grinding noise when making left turns (but not right turns).
Jan 31, 2008 at 1:46 AM
MIKE H R
  • 3,094 POSTS
it sounds like the rotors are warped. Depending how bad they are if they can be resurfaced or if you have to get new. Have a garage check the front end the grinding noise could be the brakes going bad.
Jan 31, 2008 at 2:20 AM
DRSMITH724
The brakes were replaced in April of 2007...should the rotors be warped and in need of replacing already?
Jan 31, 2008 at 8:02 AM
MIKE H R
  • 3,094 POSTS
that depends on if they replaced them in april or did they just put on new pads. With it on a lift they should be able to tell if the rotors are warped.
Feb 2, 2008 at 2:19 AM
