Security system
SHARYN43
  • 1998 FORD TAURUS
How can I bypass security system to start car light wont go out?
Sunday, January 17th, 2010 AT 3:45 PM
BMRFIXIT
  • 19,053 POSTS
There is no way to bypass the alarm system you need to reset the system to disarm it.
Here is a guide to help you.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Tuesday, December 31st, 2019 AT 3:01 PM
SHARYN43
I will try that, I rescan that doesn't work what then I don't have another key someone says it's in the computer is that why you have to use key?
BMRFIXIT
  • 19,053 POSTS
Scanning for codes should identify the problem as it maybe just a fuse of key need to be reprogrammed or not the security system at all so I would suggest getting it tot he dealer who can reset program the key for $120.00
SHARYN43
Yep thats what I did car is all fixed thanks for your help. I love this site.
BMRFIXIT
  • 19,053 POSTS
Glad you got it going, here is more information
Passive anti-theft system uses PCM to enable or disable vehicle's engine. When system is functioning properly and ignition switch is turned to RUN or START position, THEFT indicator light will turn on for 3 seconds, then turn off. Vehicle will be enabled to start and run. If there is a problem in PATS, THEFT indicator light will flash rapidly or glow constantly for more than 3 seconds when ignition is turned to run or start.
