1998 Ford Taurus routing heaterhoses
1998 FORD TAURUS
90,000 MILES • 6 CYL • FWD • AUTOMATIC
TAXMAN
My anti freeze is leaking steady with the engine running. The water is coming out in the engine compartment on the driver side. There is some type of housing against the firewall where the brakefluid reservoir is mounted on. The straight flow comes out the bottom of that housing compartment. Do I need to disassemble the brake fluid reservoir and try to the housing off to get to whatever it is that may be leaking in there? There is no leak on the inside of the car. Thanks
Ed Blokdijk
Apr 6, 2008 at 7:23 AM
2CARPRO JACK
  • 11,533 POSTS
Look real close to see if it is coming out of the drain for the HVAC plenum. That is the only place heater hoses enter the car, if so the heater core is leaking and requires the entire dash to be removed, book calls for 5.5 hrs of labor. Not a job for the faint of heart
Apr 7, 2008 at 12:57 AM
