Engine cool
remove lower radiator and upper hoses (capture all coolant )
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three times watching what leaving the heater core you are looking for the good flow and clear water to run throw
good luck
let me know
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 1, 2008 at 11:17 PM
