1998 Ford Taurus Radiator
203,580 MILES • 6 CYL • FWD • AUTOMATIC
AUNTNEATS
Will the radiator from a '93 Taurus fit a '98 Taurus?
Dec 24, 2009 at 6:39 AM
OBXAUTOMEDIC
  • 3,715 POSTS
I don't believe so. But would need more info as to Year , Make, Model, Sub-Model, Engine Size in Liters and if 3.0 liter engine is it OHV (Over Head Valve) or DOHC (Dual Overhead Cam). For both vehicles.
However, with that info you could contact your local parts store and just have them look the radiator up for both and if they are the same part number then you are good to go. Cause that is what I would end up doing.
Dec 24, 2009 at 6:51 AM
JAYBIN82
  • 44 POSTS
no i dont belive they will swap, there was alot of changes between the 2
Dec 24, 2009 at 7:21 AM
